Results 1 to 5 of 5
Thread: 5.9 auto to manual changes
    Dec 2021
    5
    Can anyone give me pointers on what all I need to change .
    I switched to a full manual valve body on a 07 5.9 cummins with a 48re.
    And I need to change/delete the things that put it into limp mode and cause defueling. As the ttva, governor pressure sensor and governor pressure solinoid are now deleted
    Advanced Tuner MAIDENCR's Avatar
    Sep 2018
    Quebec,canada
    208
    You can send your vin # with a comparable manual file and send it to hptuner they will make the change for you
    03 cummins,175% flux injectors,dual cp3,s467.7/83 1.00
    Nv5600 with valair triple disc clutch
    The regular version still has the auto trans switch beta does not anymore, under the general tab in trans
    2010 F-350 03 5.9/848ecm, built 5R110, 30% over sticks, 10mm pump, 64mm Stealth Turbo
    2008 F-350 03 5.9
    Fumminstuning.com
    Feb 2019
    Indiana
    135
    Quote Originally Posted by guy-ffc View Post
    Does that toggle actually work? I have seen mixed reviews about using that
    i'm not sure on that
    2008 F-350 03 5.9
    Fumminstuning.com
