Originally Posted by
blindsquirrel
I'd like to see a log longer than 5 seconds, and in something other than 1st gear from a dead stop. Something that will show the converter working and not other stuff in play. Like, lock it in 3rd gear at low speed, as slow as you can go (20 MPH?), then roll into it and run it up to 5000 or so, or at least above the stall speed (it will be obvious in the trace - flat line until it reaches the stall speed and then pick up and follow vehicle speed). 1st gear is not going to give you an accurate picture of the stall speed.
