Well with the help of a pry bar my wastegate has been massaged a bit more haha. Definitely holding boost better.
Wastegate rod is hard to move by hand now, and is tighter now... but I'd really like to slot the mounting screw holes and "Fine tune" the preload.
Few logs attached below
The "6th and 8th" log I took as there was obvious oscillation in that area before, but seems a lot better. The "N,D,R" log was just to see what's happening at idle. I'd like to try to make the idle smoother in D/R
3rd New2.hpl
6th and 8th low rpm load.hpl
N,D,R Idle.hpl
