Hey guys ive been working on this cammed 5.3 and have promblems with it wanting to die and dieing with a/c on heres a data log and tune21-12-16 19-12-34.hplac fix 2.hpt
needs more base running airflow
2011 Camaro 2SS Convertible L99 Bone Stock for now
2003 Dodge 2500 5.9 Cummins QC 4x4. Airaid, 2nd Gen Intake, Grid Heater Delete, D-Tech 62/65/12, Magnaflow. Bully Dog: Propane Injection, Triple Dog W/Outlook Crazy Larry. Edge EZ, BD Flow-Max, 48RE: Sonnax Sure Cure/Transgo combination, Derale turbulator, billet input, Triple Disc, Super servo, 4 ring Accumulator. :beer
You're currently in SD mode. I'd switch it back to run on the MAF if it were me. But, either way, here's a quick synopsis of the steps that will get it running.
1. Go to Engine>Idle>Airflow tables and add 3.5 gms/sec to the Airflow Final Min table
2. Go to Engine>Idle>Airflow and increase the startup airflow by 25%.
3. Go to Engine Diag>Airflow tab and change Min ECT for P0101 to 256, and change Airflow Correlation RPM from 800 to 8000.
4. Go to Engine Diag>Misfire tab and change Min misfire detection enable to 2500 rpm.
