Sounds good
Yes I agree your steps are too much. But for me it is now starting and idling on its own so for a "Start up Tune" its okay. Your desired idle rpm vs actual is really close as well as your timing. You desired airflow vs actual is off but not by much.
If you want to adjust your steps before moving on it will not hurt anything at all.
The attached file is your closed loop file I sent you with the Original IAC vs Steps table put back. With this one you can follow Hondaeater's direction to get your steps dialed in.
