Hi All! Last year I completed my swap on my 88 Suburban. I used a 2012 L96 and 6L90 from a GMC Savana 4500 van. It was a people carrier I THINK. It was too smashed up in the pics to tell. In any case, I had lots of questions about the 6.0 that was in it and how the tune would compare to the consumer version in the trucks. It was a bit of a mystery, but it turns out the engine is physically the same as far as I can tell.
My common sense tells me that the tuning on a commercial vehicle has to be different than a consumer model. Much more conservative to save on parts, not necessarily save on fuel, and set up for easy cruising.
I was wondering if anyone wanted to see the factory Savana tune file. I also have my current tune file in which Ive made adjustments so it will start and run in my Suburba, and I also ran BC Trans tool on the 6L90. Other than that, I havent touched it.
I have compared the file to a 2012 2500 truck with the 6.0, and oddly enough, many of the timing tables are similar or identical. I think the torque management is probably where things differ. The only issue is in the compare file, lots of those sections are greyed out for the Silverado. I also noticed that PE seems to NEVER come on in the Savana as far as I can tell.... I did mess with turning PE on, but either I wasnt able to get it to come on fully, or I did something else wrong because I couldnt notice any difference.
Lastly...if anyone has any advice for changes to either the engine tune...or even the trans tune...Im all ears. Im not begging for help, mostly just wanted to share the tunes since when I researched there wasnt much info on the 4500 Van engines. My main complaints about the setup is that it shifts into 6th gear when cruising up hills and doesnt want to shift back down without 75% of throttle, then shifts right back up when I let off. It lugs a LOT and that is likely hurting my MPG...which is my only other complaint. 9 mpg avg whether i take it easy, or flog it. Thats telling me there is more in it. Truck weighs 5640 lbs.
Anyway thanks! If you want to see anything logged please let me know! (Yes its name is Bruce...they all need names right?)
The Engine is bone stock internally and only long tubes installed. The trans has a ZIP Kit, upgraded the separator plates, and added a ZL1 converter based on some suggestions.
Justin
1 Bruce Original Read File.hpt
11 Bruce Modified (P0690 Removal).hpt
