Results 1 to 14 of 14
Thread: 6.0 missing tables that SCT has
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    474
    i used to tune SCT and still have the sct program and dongle. I had some pretty good success with these tables in sct. i know they are there so im assuming hpt just needs to open them up for us?
    Could we get these tables?
    2003 Ford excursion 6.0 PSD
    No limit intake
    Straight pipe
    Studded
    EGR delete
    KC billet single plane compressor wheel
    Self Tuned
    XDP Regulated return
    RDP Fuel sump
    AEM progressive water meth
    Custom suspension air bags
    8" lift
    35" tires
    You’ll need to submit this to support (they rarely check forums)
    What can speed this process up is if you know this information: table addresses, table size, data size and (possibly table/parameter ID, if you have access to the A2L parameter ID, It’s easier to find that way, as they can look through A2L and track it down fairly quickly.)
    2008 J2 F-350 CCSB
    Advanced Tuner JaegerWrenching's Avatar
    Jun 2018
    Albuquerque New Mexico
    465
    Quote Originally Posted by PSM 6.4 View Post
    This is really the only way to get things added, diesel guys are on the back burner, i have like 10 outstanding tickets with everything mentioned above.
    Jun 2012
    warrenton va
    474
    how do i find that on SCT? im looking at it now and dont see any of that info. unless there is a special way to find it lol
    How does one access the A2L parameter ID? sorry i have never heard of it.
    No limit intake
    Straight pipe
    Studded
    EGR delete
    Self Tuned
    RDP Fuel sump
    8" lift
    35" tires
    Quote Originally Posted by projectlnf View Post
    Unfortantly A2L IDs are only found in the actual A2L. A2Ls on lyman terms is ford's internal "memory map" that has everything mapped out, on a per base strategy basis.
    Side note do you have a clean unmodified stock non SOTF file for your truck? could you post it?
    2008 J2 F-350 CCSB
    That table with the mouse pointer on it ID, should be "TOW_21DNSFT_BOFF"
    2008 J2 F-350 CCSB
    Jun 2012
    warrenton va
    474
    No limit intake
    Straight pipe
    Studded
    EGR delete
    Self Tuned
    RDP Fuel sump
    8" lift
    35" tires
    Jun 2012
    warrenton va
    474
    It says after hpt fix because when I first read my file it threw a checksum error and hpt fixed it so I named it that to tell me which file it was.
    Tuning Addict
    Jan 2015
    6,787
    The way they always preferred me to do this in the past was to use a stock tune - change the table with sct or efi to all 1's or something, read entire with hpt, send that file back to them with pic of table in sct or efi then rinse and repeat with all other tables. Very time consuming, but quickest and best way... Takes about 5 or 6 hrs if you have multiple tables... AND remember to put the tables back to stock in-between each change.
    ~Greg Huggins~
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    890
    WOW...
    BTW, nice to see ya back on the forum
    2011 Camaro 2SS Convertible L99 Bone Stock for now
    2003 Dodge 2500 5.9 Cummins QC 4x4. Airaid, 2nd Gen Intake, Grid Heater Delete, D-Tech 62/65/12, Magnaflow. Bully Dog: Propane Injection, Triple Dog W/Outlook Crazy Larry. Edge EZ, BD Flow-Max, 48RE: Sonnax Sure Cure/Transgo combination, Derale turbulator, billet input, Triple Disc, Super servo, 4 ring Accumulator. :beer
    Jun 2012
    warrenton va
    474
    Well that won?t work for me lol I got rid of my SCT device. And every time I tried to read my truck after tuning it with sct it threw a checksum error.
    Jun 2012
    warrenton va
    474
    so would this be some of the information i would need if i were to do it with "user defined parameters"
    or would i not be able to do it that way? My SCT advantage doesn't show me the ID of the tables but i know the top tier/dealer license of SCT does
    No limit intake
    Straight pipe
    Studded
    EGR delete
    Self Tuned
    RDP Fuel sump
    8" lift
    35" tires
    You'll need to know the addresses for the table, data size, table size, axis addresses and the offset (For the XDF)
    2008 J2 F-350 CCSB
    Jun 2012
    warrenton va
    474
    Unfortunately I have no idea how to find most of that. I can find table size.. lol I think. If that?s just the size of how many cells the table and axis?s have?
