Originally Posted by
4wheelinls1
With what is in the tune and in the log it appears to be torque limiting, Traction control is off? You don't appear to be at any boost limits, it also pulls spark suggesting a limit.
It is likely you are missing some limits, could be torque, airflow, rate of turbo acceleration, transmission. Hard to know. Probably best to log a support ticket with all the details, infolog, debug, logs, tune file and see if they can locate and add. I do see when we supercharging the Y62 similar limiting on the throttle in 1st that we don't have access to, but it is worse with traction control on.
