Results 1 to 4 of 4
Thread: Can't see Trans Tables after Reading Car
    Dec 2021
    3
    Unhappy Can't see Trans Tables after Reading Car
    I have a Ford Explorer 3.5 NA engine 2013.
    I am trying to adjust my shifting times 1-2 and 2-3 on the transmission. I want to make it to shift a little bit earlier.
    On the VCM Editor, I do not see the complete shifting timing, Shifting properties and other tables to adjust timing of the shifting.
    On the Trans I see:
    Shifting Properties tab with 1 table called Boost time. On the torque converter I see some values but not tables like: General, Min Slip Upshift and Downshift. and Under the torque management I see one value which is Torque ;limit.
    I am not sure if its supported for this certain vehicle.
    On the VCM scanner I can see a lot of tables that are supported.
    I tried the Basic and Advanced tab same thing.
    Anyone can advise ?
    Attached the VCM editing file please take a look.
    7,615
    There is a 2013 Explorer in the repository you can compare with, looks to me like the same tables as in your file.
    Dec 2021
    3
    so that means I cant tune my transmission tables? thats disappointed as I bought this inly fir this reason at the moment?
    7,615
    No idea. Ask in the Ford section (as this is a Ford issue, not an Editor issue) and/or open a support ticket.
