Okay
Did they send you a data file with the injectors? The file I downloaded is different...
I would hate for you to change the data unless you are 100% sure its correct. If you know who entered the data into your tune you might want to see where it came from..
https://fuelinjectorclinic.com/HP-TUNERS-1000
2011 Camaro 2SS Convertible L99 Bone Stock for now
2003 Dodge 2500 5.9 Cummins QC 4x4. Airaid, 2nd Gen Intake, Grid Heater Delete, D-Tech 62/65/12, Magnaflow. Bully Dog: Propane Injection, Triple Dog W/Outlook Crazy Larry. Edge EZ, BD Flow-Max, 48RE: Sonnax Sure Cure/Transgo combination, Derale turbulator, billet input, Triple Disc, Super servo, 4 ring Accumulator. :beer
2012 CTSV FIC1000 SD base.hpt
flash this
Remote Tuning [email protected]
Not to steal any attention away from the original thread but I've been reading for a couple days trying to diagnose my Vs issue with a misfire like stumble accelerating more aggressively from a stop or even from a lower speed trying to get up in traffic. The car will only do this until about 3k rpm and then it smooths out. I had assumed the MAF curve was wonky and I did pull the tune that is currently in the car but I would really like to get it running correctly for the mods it does have.
-Brand new LSA blower sent off to Kong for porting during
build
-DMS reinforced brick
-NW 102MM TB
-Air raid Intake with 6? Green Filter
-2.3/9.1 pulleys
-BTR Stage 2 Cam (87k miles)
-New Lifters (87k miles)
-.660 springs
-DSX Aux Kit
-ID1050s w/Flex Sensor
-New Oil Pump during build (40-50psi idle, 30-35)
-ARP head studs
-Longtubes, Catless X pipe
-Corsa Sport w/magnaflow resonators
-8gal Trunk Tank
-EMP Pump
-1? lines for heat exchanger setup
-Vadder Dual Heat Exchangers
Any advice is appreciated. I would even be willing to set up some histograms from calibrating the maf with a little help.
2012 CTS-V As Read.hpt
@Ethan5.019
Changed some of your injector data, it seemed to be wrong (ECM12307, 12315, 12303), and couple other things. Just do a compare, to see a difference. Might give you some idea of what to mess with.
Your VE table is odd ~1800 - 3400 rpm, looks like it was just smoothed out.
Do a log on your MAF as well, to see where you are at. With injector changes it will most likely be off.
2012 CTS-V As Read2.hpt
Forgot PE and Flex.
You should change PE to something similar, to get into it faster.
@mememe123
So they didn't update all the injector data for the ID1050s? Do anyone have an injector data sheet or know where I can get one so I can update this before I start looking into the maf? I built a channel config and a layout for the car so I can log it once I correct the information.
The ones I put in there are from my tune, I have a '14 V with ID1050x.
ID have injector data on their website, free of charge
@mememe123
I appreciate that. I have the ID1050 on my ODIN charged F150 just wasn't certain if I could use the sheet that came with them for this application. I'll make the necessary changes and actually run a log in a few minutes.
@Alvin
It's funny you say that being that a performance shop did all the work and even dynoed the car after they did the upgrades. I've owned the car maybe 6 months but I knew something wasn't right just from the little I've driven it and finally had time to pull the file and start getting answers.
@Alvin
CTS-V log1.hpl
Here is a log of just very normal driving. I couldn't get my EQ Err Ratio graph to plot any data so I'm still trying to fight that but I am logging the MAF Freq so I'm not sure why it didn't work. This log is before any changes were made to injector data.
I can post some channels/configs when I get home, if you need them. You just gonna have to add your own WB02.
@Alvin
I will get a better log of the problem area tomorrow weather permitting. Today's log I couldn't get into the throttle and make the car act up. I will also adjust my histogram and graph so I can use the STFTs to calibrate the MAF since this car does not yet have a WB O2 sensor.
Usually when these start sputtering after a cam install the timing is too low - you do have a little odd timing table and could probably add some more in the lower rpms. However being that your VE wasn't tuned, I would look there first. Plus brand (x) injectors usually use different inj data than the regular non (x) injectors, so keep that in mind when looking up the correct data for yours.
~Greg Huggins~
@GHuggins
I just finished changing the injector data and setting the tune up for MAF tuning. I also corrected my histograms to plot STFT vs MAF Freq. I will probably flash this sometime over the weekend and get some good logs in so I can better display what the car is doing in the situation I'm concerned with. Is there a good thread to help me with the VE tuning once I get the MAF pretty close to where it should be?
2012 CTS-V MAF CAL.hpt
