Results 1 to 5 of 5
Thread: 02 sensor responce
    Jan 2021
    winchester indiana
    66
    02 sensor responce
    Been chasing leaks from intake to exhaust.Had maf scalling issues.Finally got some that squared away an now not sure but fuel trims high negitive still on one bank.possible 02 responce? that its failing an slow to respond running bank one rich?
    13,565
    Have you tried swapping sensors side to side yet to see if the issue follows the sensor?
    Tuning Addict
    6,802
    It's got a bank to bank issue causing it to go in and out of open loop. Bank 1 is super rich while bank 2 appears somewhat normal. Leaking injector bank 1 / misfire or vacuum leak bank 2? Possibly even restricted injector bank 2 if showing misfires? Logging misfires might help show the problem.
    ~Greg Huggins~
    Jan 2021
    winchester indiana
    66
    i logged missfires an had also logged indivigual injector m/s opening an seems that there not opening with relations to missfires so clogged?this was suddenly after tank of e85.Replaced hpfp o2 sensors, holding low prssure side of fuel, so down to wiring,or injectors.
    May 2003
    South FL
    1,369
    A bad lifter can cause these issues as well. Especially if the intake valve is stuck open or having trouble opening/closing and the cylinder doesn't fire. Then the oxygen for that unburnt cylinder gets picked up by the O2 sensor and the ECU thinks it is running lean and adds fuel. This isn't the only scenario that it could happen. Misfires in general will cause a bank to run rich due to the O2 sensor picking up oxygen. Remember the O2 sensor senses Oxygen, not fuel.
    [email protected]
    Owner/GM Calibrator
