Speaking of line pressure ...
Looking at a stock tune of my 2011 Corvette LS3 with 6L80E transmission -vs- a modified tune that was done to the car later on ... the only difference that I can find while looking at just the transmission data is that the 'Max Line Pressure' was increased from 726 kPa -to- 841 kPa ... this slight change made the part throttle and full throttle shifts just a little more 'firm'.
Now, I have installed a Circle-D 2,800 stall single clutch converter in the car. This converter is set up just like the stock converter in that it does not lock at WOT.
I have noticed that with this 'looser' converter, the part throttle and full throttle shifts seem more soft than before the converter was changed (and that makes sense).
Question ... If I slightly increase the 'Max Line Pressure' from 841 kPa -to- 890 kPa do you think I will get back that slightly more firm shift I had before ?
Thanks,
Ron
