Originally Posted by
TylerJDubbs
Inverse means that when you modify the table values and axis in [ECM] 29540 you must also make changes to the Table and Axis in [ECM] 29523 so that the table and axis matches up between the two tables, because if one table thinks that 750nm makes 1389mg and the other table thinks that only 550nm will make 1389mg torque monitoring will see the 750 value as an error in the torque system as the deviation is too large.
I use the rich base tables because I'm not getting paid, I'm lazy, and its easy, lol. Timing adjustment should be done with [ECM] 29490/29491/29492 - Base Spark Tables to be 100% proper
IMHO using min spark tables to substitute base spark is a NO NO as it wont use any of the corrections (IAT, ECT, ambient temp/pressure) as they apply to timing
