Hi
I am looking to modify my H3T for flexfuel.
I installed a GM flexfuel sensor and pin in E67 but before changing anything in the ECM do you know if I can use a tune from another car to compare like 2009 avalanche which is flexfuel ?
thanks
Hi
thanks
Yes, just make sure to set to sensor. A lot of early flex vehicles were virtual which used fuel trims to adjust the ethanol percentage.
~Greg Huggins~
OK
I checked the chevy avalanche 2007-2008, chevy Colorado 2010 and others, but the gas spark table is all different from the H3 V8, so I can't copy the flexfuel table from these models.
I thought it was possible with 2007-08 avalanche because LC9 and LH8 are very similar, difference is only the camshaft
I need help
Someone could check my tune for flexfuel
original
2009 HUMMER H3T STOCK TUNE.hpt
flexfuel
2009 HUMMER H3T FLEX FUEL LAST.hpt
thanks
I made a few changes
-Fuel system, Diagnostics, Set to Enable
-Code P0179 & 0179 Mill on First error
-Populated Table 12635 (PE/COT Spark correction)
-Populated Table 12636 (Mult vs Composition)
-Populated Table 12663 (Max Torque Timing Multiplier)
Other than that all needed tables seem to be populated
2011 Camaro 2SS Convertible L99 Bone Stock for now
2003 Dodge 2500 5.9 Cummins QC 4x4. Airaid, 2nd Gen Intake, Grid Heater Delete, D-Tech 62/65/12, Magnaflow. Bully Dog: Propane Injection, Triple Dog W/Outlook Crazy Larry. Edge EZ, BD Flow-Max, 48RE: Sonnax Sure Cure/Transgo combination, Derale turbulator, billet input, Triple Disc, Super servo, 4 ring Accumulator. :beer
Thanks for your help.
it works very well.
Now I look for the 4L60.
