Results 1 to 6 of 6
Thread: 2009 LH8 Flex fule tune
    Jan 2022
    Hi
    I am looking to modify my H3T for flexfuel.
    I installed a GM flexfuel sensor and pin in E67 but before changing anything in the ECM do you know if I can use a tune from another car to compare like 2009 avalanche which is flexfuel ?
    thanks
    Tuning Addict
    6,802
    Yes, just make sure to set to sensor. A lot of early flex vehicles were virtual which used fuel trims to adjust the ethanol percentage.
    ~Greg Huggins~
    Jan 2022
    3
    OK
    I checked the chevy avalanche 2007-2008, chevy Colorado 2010 and others, but the gas spark table is all different from the H3 V8, so I can't copy the flexfuel table from these models.
    I thought it was possible with 2007-08 avalanche because LC9 and LH8 are very similar, difference is only the camshaft
    Jan 2022
    3
    I need help
    Someone could check my tune for flexfuel
    original
    2009 HUMMER H3T STOCK TUNE.hpt
    flexfuel
    2009 HUMMER H3T FLEX FUEL LAST.hpt
    thanks
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    890
    I made a few changes
    -Fuel system, Diagnostics, Set to Enable
    -Code P0179 & 0179 Mill on First error
    -Populated Table 12635 (PE/COT Spark correction)
    -Populated Table 12636 (Mult vs Composition)
    -Populated Table 12663 (Max Torque Timing Multiplier)
    Other than that all needed tables seem to be populated
    Jan 2022
    3
    Thanks for your help.
    it works very well.
    Now I look for the 4L60.
