Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 82
Thread: Acronym List
  1. #21
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    WGAF?
    Kidding!
    http://www.dsxtuning.com
    Just say no to bull s***.
  2. #22
    Dec 2009
    Edinburg, Texas
    130
    Some Good info... Just what I was looking for... I was wondering what some of these things mean't.
  3. #23
    Tuner edgZ06's Avatar
    Mar 2005
    Pro Edge Tuning, CT.
    77
    Burst Knock?
    CFCO = Clutch Fuel Cut-Off but why is it there?
    2004 GTO A4
    UNDER CONSTRUCTION....
    Previous E.T. 10.66 @ 130 mph
    http://www.mongillomotors.com/1066vid.html
    2008 G8
    LS3 76mm Turbo. 582rwhp
    2003 S600 Mercedes
    V12 Twin Turbo 21psi 600 rwhp
    2007 Factor Five GTM
    Twin Turbo forged LS6 600rwhp
    2015 Polaris Slingshot
    Tune & DR
    www.ProEdgeTuning.com
    Tuning with HPTuners & Mustang MD-1100 Chassis Dyno
    Wallingford, CT.
    [email protected]
  4. #24
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,272
    Quote Originally Posted by edgZ06 View Post
    Burst Knock?
    You might want to start a separate thread in the gen 4 V8 section regarding these questions.
  5. #25
    LT B1 and ST B1
    Okay, please excuse my ignorance. I looked through these threads so I did not have to ask a stupid question but here it is...
    On the VCM Scanner Page...
    1) What is LT B1 and ST B1? I am thinking long term and short term bank one but I am not sure.
  6. #26
    HP Tuners Support
    (foff667)
    28,272
    Yes, long term & short term bank 1/2
  7. #27
    TCC? i know it has to do with the torque converter but i am looking on info on tuning for a converter and not having much luck.
  8. #28
    Apr 2010
    York, PA
    20
    Torque Converter Clutch. AKA, lock up.
    Brian
  9. #29
    Advanced Tuner printmanjackson's Avatar
    Nov 2009
    USA
    412
    what is an "EQ ratio"?
  10. #30
    HP Tuners Support
    (foff667)
    28,272
    Equivalence
  11. #31
    Sep 2007
    Florida
    59
    Quote Originally Posted by BADSZ28 View Post
    Lnf?
  12. #32
    Tuner in Training ledfootC6vette's Avatar
    Mar 2010
    Edmonton,Alberta.Canada
    19
    What is DoD?
  13. #33
    Sep 2007
    Florida
    59
    Displacement on Demand
  14. #34
    Tuner in Training 12sws27's Avatar
    Jun 2010
    48
    What is LNF?
    1998 2dr Jimmy: 1998 GMC Jimmy, 4.3L V-6, 4L60E, Wynjammer S/C @6psi, Accel 300+ ign box, Taylor 8mm wires,EGR delete, CFM-Tech tb blade, Trans-Go shift kit w/vette servo, cat delete, Hooker Maxflow muffler, Zexel Torsen w/3.42s, Marine intake, 42lb/hr injectors, 255 Walbro, HPT standard, AEM UEGO W/B A/F meter.
    SOON 2 COME:Water/Meth, JBA headers & more exhaust upgrades, cal-tracs, LS1 e-fans and some stickier rear tires.
  15. #35
    HP Tuners Support
    (foff667)
    28,272
    Its an engine code of some sort I believe for the 2.0 turbo motor. Not an acronym to my knowledge.
  16. #36
    Apr 2008
    214
    this is correct. its a gm engine rpo code
    it doesnt stand for anything
  17. #37
    Jun 2010
    48
    Oh ok. Thanks.
  18. #38
    Jan 2011
    1
    "Some more acronyms to add to the list
    AIR : Secondary Air Injection
    APP: Accelerator Pedal Position
    BARO: Barometric Pressure
    BPP: Brake Pedal Position
    BPS: Brake Pedal Switch
    BTDC: Before Top Dead Center. The location of the piston before it has reached the top of its stroke. Measured in degrees of crankshaft rotation.
    CAN: Controller Area Network
    CCM: Comprehensive Component Monitor
    CHT: Cylinder Head Temperature
    CKP: Crankshaft Position
    CMCV: Charge Motion Control Valve
    CMP: Camshaft Position
    COP: Coil On Plug. Ignition coil on plug assembly
    CPP: Clutch Pedal Position
    ECM: Electronic Control Module
    ECT: Engine Coolant Temperature
    EEC: Electronic Engine Control
    EEGR: Electric Exhaust Gas Recirculation System
    EEPROM: Electrically Erasable Programmable Read-Only Memory. An electronic component in the PCM that allows the electronic storage of information.
    EGR: Exhaust Gas Recirculation. A process in which a small amount of exhaust gas is routed into the combustion chamber.
    EI: Electronic Ignition. An electronic ignition system that has the ignition control module integrated into the PCM.
    EMI: Electromagnetic Interference. Usually caused by ignition voltage spikes, solenoids, relay operation, or noisy generator contacts.
    EOT: Engine Oil Temperature
    ERFS: Electronic Returnless Fuel System
    ESM: EGR System Module
    ESOF: Electronic Shift-on-the-Fly
    ETB: Electronic Throttle Body"
  19. #39
    Mar 2011
    4
    Sweet this is exactly what I needed!
  20. #40
    Mar 2011
    4
    Quote Originally Posted by ledfootC6vette View Post
    What is DoD?
    Turn it off and you can get a little more juice when you want it
