Results 1 to 6 of 6
Thread: injector iussues missfiring
    Jan 2021
    winchester indiana
    66
    logging my run seeing a corelation to the cylinders missfiring to injector m/s opening. are these signs failing injectors an that there clogged?
    May 2003
    South FL
    1,369
    Cyl #7 seems like the suspect cylinder to me. That happens to be a DOD cylinder. Have you checked the lifters or verified anything mechanical there?
    [email protected]
    Owner/GM Calibrator
    Jan 2019
    Bonita Springs
    108
    How old are the plugs? 7 is Definity an issue. Pull plug and see what it looks like. Spark plugs always tell the story of what's happening in the engine. No offense man, but your tune is all jacked up too. You are commanding low 11's for Power enrichment and spark is way low. Why is you amb senosr reading -40? Is that accurate or is it unplugged?
    Ryan
    Jun 2017
    10
    i had a similar problem it turned out to be the cam was worn on cylinder #6 and also dod lifter would come apart on that same cylinder
    Advanced Tuner Ghostnotes's Avatar
    Feb 2012
    Houston, TX
    471
    Might be a moot question, but does it misfire all the time or just WOT?
    Had a simar issue that turned out being a sparkplug wire being just out of spec. The plug itself looked fine since 99% of the time it was working fine.
    I always tune VVE....
    2016 C7 M7 Z51
    Callies ultra billet crank
    Callies ultra billet rods
    Diamond pistons
    Jhonson high speed lifters
    Ported and polished headwork
    Custom cam
    YSi-V7
    Jan 2021
    winchester indiana
    66
    well turns out the harness terminals on these are prone to loosing tension...problem solved no more ses light to see an wonder if it will ever be right.finally have few hundred miles under belt an good logs..
