Results 1 to 10 of 10
Thread: Updating software
    Mar 2019
    Tierra Verde, FL
    157
    Updating software
    Ive had my tune the way I want it for over a year now and have not been updating to latest stable updates. Do I need to do the updates? I only tune my car.
    13,533
    My opinion says no, I've haven't updated mine in over a year either and I have no problems doing what I need to do.
    Mar 2019
    Tierra Verde, FL
    157
    Thanks, kind of figure so as I believe updates are just for new models/years. Making sure if I want to tweak something that I dont run into issue?Cheers Rob
    Jul 2020
    VIC Australia
    1,107
    On rare occasions an update may have an extra table or 2 if another user out there requested it. That said, I wouldn't update if you are happy. The new update removed alot of important tables. You can install 2 versions side by side to see if you have new tables.
    In program files find the hp tuners folder that has the editor and scanner .exe in it and rename it to something like vcm_pre epa. Your shortcuts in the start menu etc will break but you can fix that easy. Then install the new version to look at it.
    7,450
    In more recent versions the new install completely, silently, replaces the old version, even if you try to trick it and rename the old folder beforehand or specify the new install to a different folder. At least it did the last time I tried it. It'll allow a stable version and a beta to exist at the same time, but no longer can you have two different release versions at the same time.
    Put this in the same category of 'improvements' with things like 'X Days Ago' instead of actual date/time.
    Jan 2014
    SoCal
    1,533
    Perfect time for VMware.
    Mar 2019
    Tierra Verde, FL
    157
    Thanks for all the replies. Rob
    Jul 2020
    VIC Australia
    1,107
    Not finding that with my versions (yet)
    Apr 2016
    328
    Quote Originally Posted by hjtrbo View Post
    …The new update removed alot of important tables….
    What tables were removed?
    Tuner in Training Vlad Soare's Avatar
    Dec 2021
    39
    Quote Originally Posted by NotSure View Post
    For instance, the GPF and EGR. Plus others, but you won't find them mentioned explicitely (at least I couldn't), because it seems that mentioning them isn't allowed on the forum. Such posts get promptly deleted.
