Results 1 to 3 of 3
Thread: Need Advice Please! 6L80E Shifter Positions (Pattern tuning)
    Sep 2020
    36
    Hi all,
    I am looking to do some tuning on my LSA Swap which has the 6L80/90E platform from a 2013 CTSV.
    The original stock vehicle had the following transmission shift positions on the side of the transmission housing:
    In the normal linear position on the left side of the CTSV hand shifter is PRND (D being normal drive operation)
    On the right linear side is M (+ and -) for paddle shift
    Since I do not have the paddle shifts in my restomod application and am only using PRNDM, I want to set up the transmission the same as a 2014 C7 corvette which also has the 6L80E.
    The current configuration on the C7 is:
    In the normal linear position on of the C7 hand shifter is PRNDM (D being normal drive operation, M being Paddle Mode)
    What I am looking to achieve is the following:
    Set up the M position on the 6L90 by deleting the paddle mode settings and potentially swap this to "Pattern B" which I will set up with higher RPM operating conditions the "Pattern A" (which would be the standard D position)
    "Pattern B" would then simply become a sport mode which runs about 750rpm higher across the gear range than "Pattern A" does.
    Does anyone know how I can incorporate the C7 tune into the CTSV tune?
    Has this been acheived?
    The 6L80 platform is very clever and has a very intelligent brain. surely this can be tuned into it!!!
    Craig
    Sep 2020
    36
    Or does someone have a C7 Automatic HPT file I can have a look at?
    Jul 2018
    Segment swap the transmission file
