So have a bit of a weird issue, VCM scanner will match the wideband gauge closely at idle and cruise. But when i go wot the gauge will go into the bottom 12's while VCM scanner stays around 14 afr.
I have moved the ground around a few times and currently is connected directly to the battery, have the correct wideband selected in the scanner.
Is there something else i should try?
