Originally Posted by
RecklessMotorsports
Not sure why I got listed as spammer for my reputation, maybe I posted too much.
So for those of you who are interested in tuning the ecodiesel I have a YouTube that teaches people how to tune, its the same screen name as my username here.
If anyone posts questions on here of what they need help with I will make a video explaining it, minus showing the delete part of tuning as technically hptuners doesn't support that, but if you need that done to your file we do do it for a fee.
I have been doing the Ecodiesels for my business for over a year now, mainly through other programs but the hptuners deleting has started to become popular so we are pushing to make more videos for hptuners and ecodiesels to help people out.
Hptuners has given you about 1% of the tables these computers have but that 1% is about 95% of the tables you would use minus some stuff for emissions.
A few tips I can give you right away
Under turbocharger leave anything to do with mode 3 and mode 7 stock, messing with those tables will cause you to get a p0299 if not done correctly so dont just copy and past all of your boost tables over theses.
Do not shut off code p0299 underboost or p0234 overboost - these codes have masks that are not attached to them, shutting these codes off will cause a limp mode when they are flagged with no check engine light to back it up.
Always shut off u0100 in the transmission codes as it will always throw a u0100 everytime you tune it and its annoying as hell and can scare customers
In the transmission shut off codes p0219 and p215c these two codes will cause a limp mode if they detect wheel speed issues when spinning out in gravel and snow, also annoying.
When you tune the transmission change all trans tables to target 3300-3500 rpms for wot shift, the bottom ends on these are weak and they don't make any power higher then this so you're absolutely causing issues if you're trying to spin to 4200+ like our friends up north.
When you do do trans tuning start off slow by only taking away 10% tm from main tm table, do not ever take anything away from forced torque intervention and make sure if you take away tm that you increase shift pressure by 10psi if you took away 10% tm.
Also do not change the max torque number in the transmission tuning as it will cause a u0403 limp mode and some vehicles you can't shut that off
Vane tables, if you're trying to make it exhaust break only make the max number 95% and only do it in the top row, if you do it in the second row you may cause low driving situations to go from 95% vane to 30% vane or whatever is in the next row and make the vehicle pulsate on highway.
