Originally Posted by
Jim Blackwood
Here's the latest startup. Nice quick light off, settled down to a steady idle pretty quickly, I like it. 37 degrees ect so that's promising.
King, I have questions about the Cranking FA Multiplier tables, or table. I can't do a direct comparison with yours since I have 2 tables and you have 1. (Wouldn't think that had anything to do with the 2 bar tune I'm using but who knows?) So I'd like to ask you about the upper reaches of the table and some other fine points.
-On my tables above 176 degrees the numbers drop to 0.62 and that populates the table from there up and all the way down the vertical axis as well. Is this normal? I suppose numbers less than 1 decrease startup fueling but why would it drop that much?
-At 32 degrees I'm showing a multiplier of 16 and that seems to work just fine but at -4 it's up to 24, does that seem like reasonable numbers to you? At -40 I'm showing 30.
-From what I read there is often a cyclic character to the vertical axis. As I understand it, as cranking progresses the numbers decline, then climb again, possibly to avoid flooding the engine. Have you seen this? I wonder how fast it should cycle and how far? I have no way to know how long the ECM uses each line before moving down. Should the cycle take 8 lines, 4 lines, etc? and should the multipliers vary by 10% or so? 20%? Just asking for your thoughts on this. Obviously since I have the double tables I can put in twice the number of cycles. But as long as it fires right off it'll only ever use the first couple of lines.
Jim
