Originally Posted by
Jim Blackwood
Please help me to understand the Transient settings.
First here's a datalog screen print of four startups beginning at 60 degrees and up to 81 degrees. All worked acceptably well until the last one which was unsuccessful. Note also the last two, at 70 and 81 degrees showed a spike in the injector PW. Now I may be wrong, but I see the ugly hand of the transient settings at play here and would like to fix that.
So, next I have a screen print showing 5 things, please take note of the settings. As far as I know these are typical numbers but I'm inexperienced:
-Fuel From Wall Stabil: 1.00
-Fuel On Wall EXP Decay Mult vs Airflow
-Fuel Boiling Time vs Coolant vs MAP
-Impact Factor Gain vs Airflow
-Fuel To Wall Impact Factor vs Cool Temp vs MAP
So first off, am I looking at the right area? If so, first question:
-Is the Impact Factor Gain vs Airflow relevant for a Speed Density tune with no MAF? If not should those numbers be set to zero? 1? some other number?
-Is the Fuel On Wall EXP Decay Mult vs Airflow relevant and for the same reason? If not, what multiplier should be used there?
-Is the Fuel From Wall Stabil correct? What is the effect of say halving that value?
-That leaves the last two, Boiling Time and Impact Factor. Are these two table basically the inverse of each other? In other words Impact Factor showing the percent of the shot that hits the wall and Boiling time showing how long it stays there?
-It would seem that these last two would be where my problem could lie since they both are temperature based. Would the correct approach be to lower those values in the columns from 70 degrees up?
Sorry for all the questions and thanks ever so much for your advice.
Jim
