Hey guys, I put a stage 2 Whipple kit on a 2019 mustang and also installed a set of long tubes, dual pump kit, ID1050x injectors, a smaller 3.5" pulley, and the 132mm tb from whipple. The car runs like crap so I logged injector pw and one is at 1500ms while all the others are at 1ms. I am using IDs data for return style systems using 55psi on their spreadsheet as that is what the car is at while the engine is running. I am using the Whipple base file and the ID data and it seems to be doing the best compared to just using a stock file w/ id data and the tb data. Any ideas are helpful at this point because we have run out. See tune and log attached.
1500ms pulsewidth.hpl Write 4, stock whipple cal, id data.hpt
