Results 1 to 4 of 4
Thread: Peak Brake overboost limit
    2016 ATS E80 ECM
    Peak torque
    Brake torque limit
    overboost limit
    How to Calculate Reasonable Values from Three Tables
    Jan 2014
    Australia
    1,979
    set them to a bit above your reported engine torque or axle torque output values, they are sort of an estimate of the engines peak outputs so it knows where the max possible is, just be ware that the peak torque if u adjust that it also affects your PE torque enable percentage as well so have to adjust both as u go
    Mar 2021
    8
    2016 ATS E80 ECM
    Peak torque
    Brake torque limit
    overboost limit
    8192 seems much more reasonable~~~
    8192What is the scientific basis?
