I have a potential customers who has a bad and damaged tune on there car making it run very poorly, i am just looking for stock files to use as compare please so i can get his car back up and running properly
Here is a stock 2012 STI file. HP Tuners doesn't have much for support for the subaru. I have had a few issues with not much help.
stock joshs sti base.hpt
2000 Camaro SS 408 TH400
2012 Subaru WRX STI
2013 Camaro SS
2001 Corvette Z06
I appreciate the info, What issues are you having?
2014 stock wrx
i will send you the scan file off the car, everything is stock except tq limits.Attachment 117194
also to remove the patch you have to write entire in vcm editor. if you only write calibration it will not remove the patch. Also, keep in mind you need to keep your laptop charged and vehicle battery on charger to help prevent a failed flash, a failed flash on a write entire flash can brick a computer
