Originally Posted by
jacep
I've been messing for a while with a 2017 3.5 ecoboost and am amazed at the capability of the stock motor. For the most part I am really happy with the way things are going, but have a few areas that are currently kicking my but.
Desired airflow is crazy high compare turbo airflow. What tables are used to calculate the desired airflow? I've messed with turbo calculator, expected TIP, desired airmass Max load and several other things, but I'm not seeing a connection to any of it.
As the truck starts to come into the initial boost and torque peak I get a lean spike, it only happens on the initial spool up and does not continue as it shifts through gears. I've messed with speed density tables, transient fuel, max injector angle etc with no luck in correcting the problem
Torque converter lockout for a F150. Is this such a thing on the F150. I always have torque converter slip, and I can't get it to apply any line pressure in 1st gear to help reduce the slip.
Right Now the truck is bone stock on E20. I'm waiting for exh, downpipe, intake, and intercooler to arrive. Any insight would be greatly appreciated.
