How much would the numbers vary for a 2014 L83 with BTR 2nd stage truck cam?
Thanks.
This is showing what to change for the hpfp for cam lobe to make it deliver and run smooth - should help fix bucking caused by odd pressure spikes. You can use the hpfp pressure settings if you like, but will require A LOT of reshaping of other tables to correspond. BUT if you do, you'll be 100x happier Just grabbed Dominatorstang's calibration to demonstrate.
I may or may not do some write ups for gen v stuff as there are a few things including the torque model calculator that really doesn't seem to be working correctly and requires hand modding of "select" tables in hpt to get things like timing and torque to go more in line with what you want, but I've been going in behind some pretty big name shops to fix stuff that's very time involved so not sure yet.
Anyway - use at your own risk....
~Greg Huggins~
For the fuel lobe I hadunder cam changes in the first post. But as GHuggins points out, it can be done much better in the way he shows. The Y axis method came to me from a few posts on here as another common method being used too.Fuel System>Fuel Pump>Injection Refill - scaled y axis for edge angle for 14% fuel lobe on cam
P.S. After countless weeks of fine tuning some things on my tune and struggling with other things on it, I contacted GHuggins and had him take over doing my tune. His changes have greatly helped drivability, MPG, and power across the board compared to what I had come up with. The list I put together in the first post I feel is still great to get started on self tuning with similar mods. But I have learned working with GHuggins that it only lightly scratches the surface on what an in-depth truly optimized tune offers.
How do these hpfp changes relate to other fuel lobe sizes? similar for bigger or smaller than the cam referenced?
And what other tables are you referring to? I would like to be 100x happier, just trying to understand how deep the down the rabbit hole this would send me..
Good stuff though, Thank you!
Believe it or not - you're going to have to do a whole other level of an OE in depth re-tune!!! HPFP settings are going to change EVERYTHING from torque, air and spark models to other stuff like idle, dfco and fuel multiplier controls. With more pressure you can typically run more timing, but things like torque modeling and ESPECIALLY DI fuel timing have to be really close to ideal. Is it worth it in the end - oh hell yeah. Is it going to take a lot of time and make you learn a thing or two you only thought you knew - you can bet your ass
The main changes you need to make just for the lobe are the leading, trailing and pressure dc... You can run stock hpfp settings if you want and then you wouldn't have to worry about doing the full re-tune. If that's all your after... Also watch out on certain yr models - certain ones don't like to have the pulsewidth values changed without throwing them into rep...
~Greg Huggins~
Curious what ever happened with this? Did you ever set a fixed cam retard and tune, specifically around VVE? I've noticed on my E92 from a 2016 Camaro that it appears VVE can only be edited at 0 degree intake. I figure the best approach would be zero out the desired angle high table and tune from there.VVT effect on virtual torque and VVE - I am not to this step yet, but set a constant valve timing degree and use logs to tune VVE and virtual torque tables at that degree.
If I'm understanding this correctly you're asking if you can pretty much just set it up to use the one VVE table by killing the others by 0ing out the corresponding coefficient tables for cam movement - short answer - yes - BUT only do this is you're running a fixed cam as it will drive and operate better by maintaining an OE setup and as far as that goes, you shouldn't even need to 0 it out then as the ecm technically shouldn't be using any of the other tables anyway.
Now if you're not running a fixed cam and you want a truly OE level tune - lock the cam at 0 via the tune - tune in your 0 VE table and I do mean TUNE it in whether you have to keep it in lower gears and rev it out or play in it a little to get as many odd by cells as possible. After doing this what I've found to work the best is to keep a 0 position fuel error log for reference and then using the coefficient tables - dial your other cam positions VE tables in to roughly the same fuel errors. Personally I get the 0 position VVE and then just use the error differences to rough in the coefficients to keep that close and then you can always skew things slightly on the 0 table to get a better average for all of the other positions. I really wish with everything HPT has done in these regards that they have made a way for the editor to properly calculate these tables as educated guesses are about as good as you can get with them.
~Greg Huggins~
Here is the filter I was using and fairly sure it came from another member on this forum, just can not remember who to give credit for it. If GHuggins gets a chance to chime in then he may offer a filter that he has refined out too.
[2517.161.avg(1500)]=0 and [2517.161.avg(-200)]=0 and (abs([50090.156.slope(1500)])+abs([50090.156.slope(-500)]))<2 and ([6310]=9 OR [6310]=14 OR [6310]=15)=0
Gen 4 Dyn Air thread going on right now. New formulas and filters in there.
~Greg Huggins~
GREAT thread and great help here - it's what I used to tune my Gen V for headers, cam, with DOD and VVT delete!
Love the choppy 900RPM idle, never stalls, WOT always 99.6% throttle and spark where I set it, 28MPG hiway at 80MPH - I love it.
SOI table adjusted for valve events with fixed timing cuz no VVT, and to center the squirt based on how long injectors open for different loads/rpms.
I started with VVE and VVE adjusted up from stock based on % dyno chart changes between stock and headers/cam, I've changed those back to stock >1200RPM.
Now that I've been driving it a couple of months I do have a couple of questions:
- really smell raw gas behind the car at idle - Commanded lambda is 1, wide band shows 1, is it because it's DI?
- VVE and VT are now both stock again above 1200RPM but at WOT, commanded lambda is 0.85 but wideband still shows 0.79 - I've been unsuccessful causing any change in wideband reading. Should I play with SOI, could the injector be spraying too late or early?
2019 C7 Stingray M7 - long tube headers, 6.30/6.22 226/238 cam, supporting stuff, DOD and VVT delete.
Stock everything else
Your SOI table isn't changing for load. It's the same with light load as it is with full load.
Your mpg's are impressive. Personally I prefer to dial the VE in, but part of the reason for your mpg's is you're causing a lean cruise condition with the VE being raised up above actuality. This is actually causing the throttle to be held open slightly via the torque model. Up to you on whether or not to dial it in.
Focus on the soi - maybe run an altered stock version based along the lines of your current changes?
~Greg Huggins~
Really appreciate your feedback!
wideband shows dithering around lambda 1 at cruise so i feel like I'm good there, right?
but I looked at SOI, you're right!, low load is the same as hi load, I only accounted for RPM so I will redo it and let you know, thanks so much!
Something about how the torque model makes things work. A fine example is to lower the model a bunch or raise it - doesn't really matter - just needs to change a decent amount - it'll still run at a lambda of 1, but will require you to change your fueling. I don't understand it. Not at all, but I've used this in a different method to do the same thing and I know others do this in their tunes constantly with the VE tables for the same reason but it basically makes the engine hold the throttle open with less pedal causing it to run slightly leaner and with slightly more timing. I've been able to get stock 6.2 trucks with a cai mod up in the high 20's doing the same method, again just from a different attack point.
When the engine is mechanically modified it's harder to do. Pretty much only way to do it is with the VE being falsified. Personally I still prefer to dial everything in. Seems to do better all the way around.
~Greg Huggins~
