i don't have any good background on this, whole swap was done by someone else and i'm just another stop by the owner on the way to trying to get it fixed.
the computer comes up an 09, but it also has an 8sp swap with the dial gear change. was the 8sp available in 09? i don't think so. but i mention it because it might be helpful.
what's happening is the pedal suddenly goes limp at highway speeds. even at steady throttle, it will do it. when it happens there's no codes or anything to help troubleshoot.
the vehicle is a 51 dodge truck and owner was told the whole thing came from a single donor, ecu, harness, pedal, engine, trans.
there's no speed in the log which seems unusual. unfortunately i didn't log anything from the trans and truck isn't here currently. this could be the source, i don't know. the dash has a gps driven speedo.
in pedal3 file it happens at 8 seconds. you'll see the spark graph suddenly drop. in pedal5, it's at 1m and 25 seconds. the spark suddenly goes sawtooth.
in all cases the accelerator pedal position sensor goes to zero (which is closed throttle reading too). my first thought is maybe the APP should be replaced, but key off and on and everything is back to normal. and keep it under 65mph doesn't happen.
any help is appreciated before we start throwing parts at it.
