Results 1 to 12 of 12
Thread: Procharged LSX-LS7 Tune issues
    Jan 2022
    4
    Help. Trying to get my tune cleaned up for the Sick Week event in FL starting in 10 days. The general tune is pretty sloppy at the moment but the main issue is starting. It requires throttle input cold and hot.
    I'll attach the tune and a Dyno log. Car does okay at WOT and is reasonable safe.
    Setup is: Forged LSX- LS7 port config. D1X 3.5 pulley makes 19lbs. 242-248 .635 .635 cam 118+4 lsa. NW 103 (the new one) Fuel Injector Clinic 1700's. Flex fuel setup. Methanol injection. Willing to work with a guru and send logs.
    Thanks. Any questions, just ask.12-31-2021 18.5 timing Sick Week.hplSickWeekTune.hpt
    Aug 2014
    Central, LA
    737
    Do you have a return style fuel setup (boost\vac referenced)?
    Aug 2009
    Calibrating
    3,373
    Hit me up! I’m sure I can help
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Jan 2022
    4
    Quote Originally Posted by sevinn View Post
    Yes. 450 in tank, then a Magnafuel 4303 that triggers 1 of 2 ways. Also run a FMU that ramps the Magnafuel voltage to 16 volts during the run. My fuel system is pretty trick for a Vette. Lack of fuel is not the issue.
    Jan 2022
    4
    Quote Originally Posted by Ben Charles View Post
    Sent you a DM.
    Aug 2009
    Calibrating
    3,373
    Just looked at it, ITS BAD.... Sent you a PM with my opinion
    14 Gen 5 Viper
    Mar 2011
    Ripley, MS
    1,865
    Ben, I just looked at it as well. It's pretty bad. That MAF table...Wow!
    Nov 2009
    All Around
    3,149
    fun and nice setup, let me know if we can support
    just saw the cal, yeah needs major work
    Aug 2014
    Central, LA
    737
    Quote Originally Posted by NuBalnc View Post
    I was just wondering because of settings I saw in the tune. It needs to be started over, let ben help you. Probably have to quarter scale those injectors instead of setting them maxed out...
    Tuning Addict
    Jan 2015
    6,791
    I'm surprised it'll crank and run at all with the VE tables blank...
    ~Greg Huggins~
    Jan 2022
    4
    It did start but needed throttle input until the ECT's were above 130. Ben's first tune started right up and idled with zero throttle input. We are on the 3rd revision and its running great so far. Very pleased with Ben so far. Pretty positive this thing will be perfect once I get the car down to Florida where I can get him some logs under load. The Sick Week event starts next Sunday and I am wrapping up a ton of loose ends before I load the car and head South. Nice that Ben is so easy to work with and making exponential improvements.
    Nov 2009
    All Around
    3,149
    yes Ben is a great asset to the community, glad its working out
