Results 1 to 4 of 4
Thread: 2002 lq4 no manual transmission setting
    2002 lq4 when i dowload stock tune and want to change the transmission to auto to manual but the setting is not there anymore all that it says is prdl am i foing sonething wrong or did the tune not read right
    405
    2,331
    Is your view set to Advanced? Changing that does not make it a manual OS. And the PRNDL setting is in the System Tab. Trans type is in the Trans Tab Shift Properties.
    13,569
    What he said. Changing the transmission type to manual does nothing.
    You don't need to change the setting to manual, it will work fine without changing it. I read that changing it can cause problems aswell.
