Results 1 to 5 of 5
Thread: 2006 Silverado 1500 2wd 4.8 to 6.0 need help
    Feb 2022
    2
    so i swapped in a rebuilt lq4 sloppy stage2 cam ,valve springs, 1 3/4" longtubes, 3"dual exhaust ,cold air intake .. what size injectors should i run 42lb 50lb? im running stock 4.8 ecm , intake, throttle body and maf ... just trying to get it drivable so i can datalog and get a proper tune.. oh yeah its a 4l60e 3.73 gears 275/45/20 tires
    13,565
    Later model 5.3 or 6.0 injectors are a very common swap and they are cheap to buy online. The 5.3 flex fuel's are usually 37-38lb/hr if I remember right and the 6.0 injectors are 50lb/hr because they are flex fuel as well.
    You can convert the GEN 4 data into GEN 3 format with ease using a spreadsheet. Input the data from the tune with the injectors you are using and it will convert the values for you.
    You'll also want to copy over a stock 6.0 tune with the compare feature to give you a good base to start with. Find a 2006 stock 6.0 truck file and just copy over the entire engine section with the compare tool.
    Feb 2022
    2
    Thank you
    Using the compare feature, do I need to do every table individually? Or is there a faster way?
    Thanks for the helpful replies, I am doing a similar thing. In my case replacing a 6.0l with a 4.8l.
    7,649
    Quote Originally Posted by rockchip View Post
    Compare > View Comparison Log
