Results 1 to 5 of 5
Thread: 2010 Camaro LS3 E38 single turbo/ Afterstart Enrichment tuning
    Jun 2020
    Wyoming
    3
    Tuned the Gen 3 platform before. Now tuning a gen 4 E38 with a boost cam and custom single turbo. Where is the after start enrichment tables? Is it "open loop gains?" My AFR is 8-9 for the first 5 seconds which is to rich after starting then leans out to the AFR I want it at. I need to lean it out.
    Jan 2022
    40
    There's an EQ ratio table under Engine-Fuel-Power Enrichment. Check that out and see if that's what you're looking for
    Advanced Tuner 4wheelinls1's Avatar
    Jun 2009
    Melbourne Australia
    284
    Quote Originally Posted by greenjeens View Post
    There is a command and an Intake Valve temp correction, Set the open loop table to your desired mixture when cold and then adjust the ITV gain to achieve that mixture.
    Tuning Addict
    Jan 2015
    6,872
    You need to make sure startup airflow, injection timing, injector tip temp and most importantly VE and/or MAF if being used, are right first.
    ~Greg Huggins~
    Jun 2020
    Wyoming
    3
    Excellent thank you. I will give all the tables a try to see if I can get it leaned out.
