new to tuning any ideas on my tune
Frank, is that all the information you are going to give?
No cam specs, other mods or problems you are having?
Where are the data logs?
What cam was used exactly.
What else was done aside from a DOD delete?
I just finished assembling a 2007 Suburban 5.3 LMG. TSP LOWLIFT STG1 114LSA and K&N CAI. I simply disabled DOD, upped the rev limiter Parameters and changed its shift points along the range an 6100 at WOT.
Cam is so mild (and well engineered, I didn?t have to touch idle tuning.
If you put a big chop-a$$ cam in it, you?ll need to work on idle tuning for absolute sure.
These are land Yachts at 6300lbs. No point in pissing around to squeak out an extra 8-10hp from a tune, you?ll never feel it. The cam alone made this thing an Escalade interceptor.
Let us know
