Results 1 to 7 of 7
Thread: Converting 2wd to 4wd
    Feb 2022
    5
    Lightbulb Converting 2wd to 4wd
    Hello there been looking here for a little while 1st time posting
    I have a 2002 Sierra 2500 non HD I'm converting to 4wd with a NV 246 Transfer case. This Transfer case is the 4 button style. Is there a way to activate the 4wd drive parameters? Is this something that can be segment swapped? I'm having a hard time finding the file I need, If that's what I need.
    OS #12212156
    2002 2500 6.0 4L80 2wd.hpt
    Jul 2021
    Central, upstate NY
    4
    There are no parameters in the PCM for transfer case operation. The pushbutton transfer cases in '02 Serrias, prolly also Silverados, are controlled by a module under the dash. I've got two 411's I'm working with, an '02 and '03, both from 4x4 trucks, going into 2-wheel drive trucks, and I haven't found anything relevant to transfer case controls yet. The '97 & 98 4x4 push buttons I've worked on have a dedicated control module under the dash, separate from the PCM. My '02 4x4 donor truck, has a body control module under the steering column that is linked to the PCM via class 2 data link.
    Your conversion is going to be more involved with transfer case wiring harness power and switch integration and body control module physical swapping than PCM configuration.
    Not to mention the physical fabrication work of removing front suspension and steering and installing an IFS differential... unless you're going for a solid axle swap... that's prolly easier from a fabrication point because some 2WD frames have different geometry to mount the front springs and components making the conversion process more difficult. At least in the C3500s anyway it's more difficult to convert to 4x4.
    Feb 2022
    5
    Lightbulb
    The fabrication is the easy part. I have reversed engineered that wiring harness with the TCCM. And I just got a free pcm today that has the build to it. I'm essentially installing a factory item on a truck. Can I just swap computers, power up the wiring harness, and see if it shifts?
    OS #9379910
    2001 2500 4x4.hpt
    Feb 2022
    5
    Pictures Are NOT loading
    Feb 2022
    5
    Bump?
    PCM doesn't control transfer case. It has it's own module like bend wrenches told you.
    Feb 2022
    5
    bump BILL?
