Originally Posted by
Simona A. Zielinski
Hey there! It sounds like you're having some trouble with your 2018 Silverado and trying to replace the value for parameter 2312.
Based on the equation you provided for GMVE, it seems like you're on the right track with trying to replace the 2312 value with a calculated value based on other parameters. If you substitute the values you mentioned into the equation, you should be able to calculate the GMVE value for your truck.
As for your question about making a math for GMVE when it is not logging, it's difficult to provide a specific answer without more information about your situation. However, it's worth noting that the GMVE value can be affected by a number of factors, including engine load, air/fuel ratio, and more. If you're having trouble with the GMVE value, it may be helpful to consult with a mechanic or tuner who has experience working with your particular vehicle to diagnose and resolve the issue.
I hope this helps, and best of luck with your truck!
