Results 1 to 11 of 11
Thread: 96-99 l31 5.7 vortec info
    Jun 2021
    Texas
    27
    i made another post but i want to make this thread as well as there isnt much info besides like honeybadger on youtube so if anyone needs help on a 411 PCM swap or the pinout, cam swap questions my tune injector swaps how to tune after a cam swap just shoot me an email or respond here if I dont answer shoot me a email its my name
    1996 5.7 vortec k1500 (4x4) 411 pcm swap ,lt4/lt1 hot cam ,1.6 rockers, mpfi upgrade, cai, long tube headers ,true dual exhaust getting ready for the turbo
    lmk if you need help with your 96-99 vortec just text my number
    email :marcodiazc158@gmail.com
    (956)784-1824
    Feb 2022
    Is there a way I can get a pin out sheet to swap a black box PCM from a 98C1500 to a 411PCM
    Feb 2016
    Texas
    531
    E mail Lextech for easy to use pinout spreadsheet. $20usd or go to lt1swap.com and cross reference the pinouts with a black box. and start swapping wires over to the new 80 pin connectors.
    97 ext cab short bed silverado 5.7 411 swap, edelbrock 29135 intake, lightly ported 906 heads milled .035 thou. factory press in rocker studs & rockers, comp 787 retainers & stock locks, ls6 springs. Comp cams 08-503-8 T56 swap
    86 SWB crate vortec 5.7/th350 The wife's truck
    Jun 2021
    Texas
    27
    Cool
    yeah shoot me a email
    you will also need to crank relearn
    i havent figured out how to insert files here yet so bare with me lol
    lmk if this works hpt has a relearn function in the vcm scanner there you will go to the little green button that says special controls and functions and go to crank relearn from there it will tell you what to do
    IF YOU HAVE CHECK ENGING LIGHTS THE ECM WILL NOT RELEARN FIX YOUR PROBLEMS FIRST
    https://docs.google.com/spreadsheets...f=true&sd=true
    gm-crankshaft-relearn-instructions.pdf
    wiring.txt
    (956)784-1824
    Feb 2016
    Texas
    531
    This is a direct file from lextech. These spreadsheets he has specifically asked everyone not to share. Rightfully so in my opinion, Your not helping by posting this. Your showing how to disrespect Jeff and the people who helped him build this xcel spreadsheet by using this file as your own.
    Rarely have I needed to complete a crank re learn for a pcm swap. As long as the distributor is adjusted within 5 degrees + - cam offset, everything should be fine.
    Jun 2021
    Texas
    27
    why would i make this dude pay 20 dollars for something i already have thats like asking someone to pay you for a forum you decided to be in and give advice , i purchased this excel from someone else so i dont know who you jeff is and i own it meaning i can share it ?and if you put in a cam and new balancer ,rotating assembly ,crankshaft sensor or camshaft its recommended to do a relearn truck will still run without a relearn but it may cause other issues down the road
    (956)784-1824
    Feb 2016
    Texas
    531
    Nothing further from me. Do as you will this is a free country.
    Jun 2022
    4
    Can someone put me in touch with lextech? I'm trying to get a pinout for my 1997 k1500 5.7 to do the 0411 swap. I'm new to the forum and not sure how to get in touch with him. I'll pay the $20 just need to get in touch with him. thanks
    Jun 2022
    4
    does anyone have a way to contact lextech? I dont have his email information. I need a 0411 spread sheet for my 97 k1500 5.7
    Feb 2016
    Texas
    531
    Check your pm's
    Jul 2010
    Illinois
    7
    I've been trying to get ahold oh him now for about 3 months for a pinout. He must be a very busy man. So finding this thread with the 1996 truck pin out that i need is a blessing right now. sorry and thank you at the same time. He must be busy or going threw something to not be able to answer. Thanks again marcodiazc158@gmail.com
