Hey all, had my tune dialled in nicely on a loose stall and have now swapped to a much tighter converter that can handle WOT lockup. Now I can lock up at 1000rpm and mash the throttle to get a fuel tune run in. What I'm noticing at 5850Hz (1600rpm) and 7350Hz (2550rpm) is I'm having these weird bumps in my MAF curve to get the wideband reading right. I did not have this issue on the old converter as the engine rpms were much higher at those MAF Hz as the converter was flashing.
Doing some reading and have other examples and the consensus was the injection timing. I already have it adjusted 30 degrees overall but am wondering if I should utilise the RPM table (currently all 0). Also tried adjusting dynamic enable up to 4000rpm and at 1800rpm. Both settings does the same thing so it's not that.
Wondering if someone could take a look?
6.2L LSA with pulley upgrade (10-11psi)
Harrop cold air intake
Cam card attached
1-7/8 Headers into twin 3" cat delete system
DW1200 injectors
Ignore a couple of dodgy things in the log. Still have transient / manifold volume on initial WOT tip in to sort out. Also note VVE was jacked up just as a test. The tune file supplied has my old VVE table which is close to spot on.
