2018 gt return style fuel system and centrifugal supercharger
I have made changes with regards to the injectors , is there adjustments that im missing for the fuel system? at the end of my test drive the idle would not stabilize.you can see the oscillation here as I let it sit for about a minute.
You should lower your idle to 750rpm because you have it at 850 and you optimum stability map points switch at 850rpm. so its bouncing between 2 points. And your also missing a lot of data you need in the log. Lift pump pressure is a big one and map points.
