Results 1 to 8 of 8
Thread: Gm Delphi 52lbs injector with p59 ecm?
    Nov 2018
    47
    Got a buddy wanting to run the 2008-13 52lb. Injector. But the newer ecm doesn?t characterize the injectors the same way as the p59. Is there a way to get the injector data that will work in the p59 for those injectors other than a gm tune file?
    7,643
    Do you have any ID info for the injectors other than '52lb', like a real part number?
    Mar 2011
    Ripley, MS
    1,865
    Quote Originally Posted by Garyg View Post
    Are you referring to the 12613412? It's the 6.2L flex fuel truck injector. There is a Gen 4 to Gen 3 conversion spreadsheet that will help you out.
    https://forum.hptuners.com/showthrea...13-to-2006-6-0
    Nov 2018
    47
    OEM NEW Delphi Fuel Injector GM # 12613412
    Nov 2018
    47
    Yes!! Thank you!!!
    Nov 2018
    47
    So I got the converter but with a flex fuel vehicle the labels are different than what?s in the converter for the 08-13. Do I just put the info in order from left to right and not worry about the labels?
    7,643
    Flex Fuel Injectors in E40 - 12613412 DSteck.hpt
    E40 tables are very similar to what's in Gen3s.
    Nov 2018
    47
    Thanks!! I think I?ve got it now.
    This is so much easier with aftermarket injectors.
