Results 1 to 3 of 3
Thread: AEM not working with hpt
    Jan 2019
    1
    I recently wrapped up my LSA swap on my tbss. Doing a few logs for my tuner we noticed the the AEM 30-0334 is no long working with hpt scanner. Gauge still works though. I tried using the WB EQ Ratio 1 (SAE) but it it doesn?t even show up to add the pid . It showing greyed out in the channel but when you start to log it disappears. My tuner did use a custom OS if that makes any difference. Any thoughts?
    Jan 2022
    40
    Try repolling for vehicle a couple times. You might also try resyncing the interface too. I had this same issue last week, and doing the repoll and resync got everything working again.
    Jan 2014
    Australia
    1,979
    change the pid number for the gauge to like 6 so it may show up as WB 6 then see if its working, some ecu have those first couple spots taken so it wont show up using no.1
