Ok I suck at the search or just it?s not there to search, I am buttoning up my Tj hemi swap for the second time. I have been driving it fine with just the manual but for the eldest kid to drive it i had to put the auto in it. So here is my problem when I go to read the PCM it says ignition cycle times out. But I can read all live data. I can get the trouble codes as well. It will just not read the PCM or TCM. Has anyone else had this issue. Funny thing is if I use a friends snap on scanner I cannot read engine codes with it but it will read the tcm. any help would be great. I have 2 OBD ports one under dash the other under the hood. I just installed the second one in case I crossed a wire but was not the case. It is an 2004 dodge 5.7 hemi with a 45rfe or 545 rfe. Stuffed into a TJ
