Tuning a big cam (GPI Stage 3 226/246 .639/.639/112 +2 ICL) LT1 C7. My first big cam LT1 tuning experience too, so big learning curve. I've researched the forums for common GenV idle tuning principles, and I got it to at least idle with zero pedal, but it's still idling too low (currently 650 vs my target of 850) and stalling easily when "returning to idle" during a clutch in.
I've already:
Lowered VVE to about 80% of stock, got it ballpark on fueling with wideband on OL.
Switched over to MAF only, and rescaled the MAF, got it ballpark stoich with wideband on OL.
Cleaned up virtual torque tables multiple times (Airmass and MAP) to be closer to 50-100ft lbs in idle areas of around 0.20-0.30g air mass and 60-70kpa manifold vacuum pressure.
External Load, Torque reserve, all revised...
Driver demand revised (only for over 60-70% pedal areas though)
32% fuel lobe accounted in leading angle y axis scaling (not that it matters that much for idle I think anyway)
Because the cam is so jumpy, at this point I'm not sure what direction I should be going with the Idle Torque tables and Virtual Torque to continue moving in the right direction to get the idle closer to 850 instead of 650 and get it not stall after a "return to idle" clutch in. Looking for some pointers on what to log and look for to get closer. Tune and logs attached.
2014 Jonathan C7 HCI Calvo Tune.hpt
Jonathan C7 HCI idle log.hpl
Jonathan C7 HCI cruise and some WOTs.hpl
PS: O2 readings might look wonky at parts of the drive logs, because we found a spark plug that had a cracked insulator. Spark plug has been replaced since.
