Page 3 of 3 FirstFirst 123
Results 41 to 48 of 48
Thread: 2016 L83 w/LT4 pump erratic fuel pressure
  1. #41
    Aug 2010
    Detroit, MI
    1,090
    It wasn't exactly a public thing lol.
  2. #42
    Tuner lynmup's Avatar
    Dec 2020
    Omaha, NE
    156
    Wound up buying the DSX aux pump and it is performing wonderfully. Took a bit of trial and error to get the pressure to act right but it is doing great...now trying to fix my lowside control but think I've got that sorted.
    Stock Sucks but IT's reliable!
  3. #43
    Anyone having any issues with their tank fitting leaking? Just checking before I pull the trigger on a dsx system
  4. #44
    Dec 2020
    Omaha, NE
    156
    Use the sealant they provide and don't go too deep when using the tap. I've removed my tank 5-6 times since installing and no leaks at all.
  5. #45
    Quote Originally Posted by lynmup View Post
    I?ve seen videos and the people?s fittings are always loose as fuck, (I?m a plumber by profession) and that loose fitting shit doesn?t sit well with me, was your?s snug?
  6. #46
    Dec 2020
    Omaha, NE
    156
    Snug as a bug in a rug. Keep the NTP tap shallow so you get a good bite. No leaks from mine but if it does ever leak, I plan to get a bulkhead fitting but it's doing great so far and I've removed the tank at least 5 times since installing it this summer. This is the best pic I can get for now.
    Not certain about your tank but the tank in the Yukon was exceptionally thick.
  7. #47
    That?s what I like to hear, I have 23 Silverado and I?d imagine it probably has the same type of material as your?s.
  8. #48
    Dec 2020
    Omaha, NE
    156
    Probably better!
