I am working on a 2001 Firebird that has an LS3 swap and lingenfilter x58 to x24 converter. The light on the box it self stays steady green while cranking meaning it has a steady crank and cam signal. I dialed in the injectors as per the green and yellow sheet, VAT disabled and went to a point where maxed out the injectors but the car does not run. It keeps cranking only.
We checked voltage on the injectors connector and they are all good. I get 0.5v ignition on and bumps to 2.2v while cranking. However, nothing comes out of the injectors at all not a single drop of fuel.
I've attached the tune file hoping someone can shed some light on the issue going on.
Is it from the converter that its not triggering the injectors or is it a tune related issue!!
I do get RPM while cranking and actually it ran fine when we sprayed some fuel into the intake.
