Results 1 to 16 of 16
Thread: LS3 swapped Fireberd
    Nov 2019
    Bahrain
    77
    LS3 swapped Fireberd (SOLVED)
    I am working on a 2001 Firebird that has an LS3 swap and lingenfilter x58 to x24 converter. The light on the box it self stays steady green while cranking meaning it has a steady crank and cam signal. I dialed in the injectors as per the green and yellow sheet, VAT disabled and went to a point where maxed out the injectors but the car does not run. It keeps cranking only.
    We checked voltage on the injectors connector and they are all good. I get 0.5v ignition on and bumps to 2.2v while cranking. However, nothing comes out of the injectors at all not a single drop of fuel.
    I've attached the tune file hoping someone can shed some light on the issue going on.
    Is it from the converter that its not triggering the injectors or is it a tune related issue!!
    I do get RPM while cranking and actually it ran fine when we sprayed some fuel into the intake.
    Mar 2011
    Ripley, MS
    1,865
    It's not the tune or the conversion box.
    Is the fuel pump coming on? Have you verified fuel pressure?
    You should get 12V to the pink wire on the injectors with the key on and during cranking. If you don't, start checking fuses.
    Nov 2019
    Bahrain
    77
    Fuel pressure is good, i do get fuel all the way to the fuel rail. Fuel pump is working fuel pressure is 55ish psi.
    I will check the pink wire today and will update the post
    Jun 2007
    Finland, Europe
    549
    What is the PCM voltage during cranking?
    Jun 2007
    Finland, Europe
    549
    What is the PCM voltage during cranking? If it's below 10 volts it will do cranking but does not start.
    A log would be nice.
    Nov 2019
    Bahrain
    77
    Quote Originally Posted by Pekka_Perkeles View Post
    I did not check that
    I will check and confirm. I'll upload a log too
    Nov 2019
    Bahrain
    77
    Attached is the log file. I couldn't read or log the control module voltage for some reason!!
    Did you ever get 12v at injector pink wire?
    Nov 2019
    Bahrain
    77
    Quote Originally Posted by Shnraines View Post
    Yes, i do get 12v to the injectors on the pink wire.
    I am starting to wonder if its from the lingenfelter converter
    If it runs when spraying into intake, the converter is working. Vats maybe?
    Nov 2019
    Bahrain
    77
    Vats already been disabled. I have my tune file attached too.
    I tried hot wiring the injectors giving them 12v direct and that didn't work.
    Now for some reason, only cyl 2 injector is working.
    Nov 2019
    Bahrain
    77
    Update:
    Car started and running perfect., Refreshed the injectors, dialed in injectors scaling again and started from first crank
    What does refreshed injectors mean?
    Nov 2019
    Bahrain
    77
    Cleaned, new seal, new strainer and bench tested them.
    Were they clogged?
    Nov 2019
    Bahrain
    77
    We believe so, He did the injectors and went through the wiring all over again. He found a ground which was loose and the map sensor wiring was wrong although it was reading.
