What are you logging?
I'm excited I just ordered my adapter, downloaded some of the stock tunes listed here to get a feel for what I should be logging. I have compiled the below list based on thumbing through said stock tunes, many of these items show up in several sections.
I'm curious to see what others might be looking at.
Driving Mode
TPS %
TPS Voltage
Engine RPM
MAP
Engine Coolant Temp
Engine Load Percentage
Mass Airflow
Current gear
Engine Coolant Temp
Knock Retard
Boost
Ambient Pressure Filtering
Upstream Temp Sensor
Turbo Logic
Ambient Pressure Sensor
Boost Pressure Sensor
Exhaust Temperature Rate Per Second
Altitude Correction Factor
Intake Air Temp
Upstream Pressure
Input Duty Cycle
Wastegate Compensation
Barometric Pressure
Boost Error
Desired Boost
Exhaust Mass Flow
Desired Lambda,
Rpm
Coolant
Engine Load
Exhaust gas temp
Injector Pulse Width
Throttle position sensor
manifold absolute pressure kpa
barometric pressure
accel pedal position
Iat
ve scaled map
here is a Starting base for graphs
