OK, so an update now.
I've reset everything back to stock, I found an auto stock tune of the same VZ the original file was,and basically segment swapped everything across over mine.
I've got the wideband wired in to the egr now after finding i'd put the voltage into blue 65 instead of 55 so hopefully no damage done.
The exhaust still has a lot of holes in the joins so I don't think I can do any realy wideband tuning until the exhaust is done, but i'd rather drive the car to the shop than pay to get it towed if I can help it.
I've decided to leave the maf on until the tuners do their thing, but was hoping someone could take a look at the log and see if they can figure out what the narrowband o2s are doing. They're significantly different from each other, even when the car isn't running.
Note: The file attached is still with the original tune and not with the above changes I've made, ran out of time to test them, but o2 values a bit weird.
Also is there anything else I should be logging?
