I am new to tuning and trying understand where to start. I have used HP tuners for years doing minor stuff like tire size and gear ratios corrections and disabling DOD and other easy stuff.
I have a 2017 C7 GS with the 8 speed auto. I put long tube headers and cat less mid pipe on it. I have a flex fuel sensor kit I will install once I square the fuel trim adjustment form the header install. I have not road tested the car yet, I am waiting for the TCM to return from HP tuners unlock service , I did install a AEM wide band in it also "need to install the gage in the car still".
I have watched a ton of stuff online and have some basic knowledge / low level understanding of different VE, MAF, & Pe tables.
Once the car is back on the ground I will data log it, I assume it will be way off on fuel trims.
Just looking for info on where to start or the best methodology on how I should proceed.
V/R
Sloppy
