Results 1 to 2 of 2
Thread: "Diagnostics and Info" show no data
    Mar 2010
    Goleta CA
    122
    I was scanning an E38 in a 2012 Corvette ZO6. Whenever I click "Diagnostics and Info" there is no data. When I connect a traditional scan tester I have P0300 intermittent and pending. I also have two I/M moniters not set.
    Anyone know why that info is not appearing in VCM Scanner?
    Hib Halverson
    Just Another Tuner in Training.
    Jan 2022
    Southern California
    362
    I've learned that a lot of things don't work, so I assume if it's there and doesn't work for me, then it works for some car other than mine.
    I can also say the diagnostics for clearing codes was basically useless for me because if it's a code I need cleared, it can't do it. It clears codes that don't matter just fine. Like any $10 dongle. So I have to use a more complicated and much more time consuming program and hardware to clear codes anyway.
    '16 E550 Coupe RWD - C207.373 / M278.922 / MED17.7.3 / 722.909
